Activity Forums Apple Final Cut Pro Legacy Editing at lower frame rates?
  • Editing at lower frame rates?
    Posted by Brian Maffitt on January 16, 2007 at 6:24 pm
    Hi all,
    Sorry if this has been asked before (I checked the archives) but is there a way to edit footage in Final Cut at a frame rate below 24fps? I have a project with a ton of 15fps footage, destined for the web, and it would be ideal to edit at this frame rate, but the sequence settings son’t seem to allow it. I know I can drop it into a 30fps timeline, but then I have to render.
    Any info would be much appreciated,
    Brian
    Brian Maffitt replied 19 years, 7 months ago 2 Members · 4 Replies
  • Shane Ross
    January 16, 2007 at 6:32 pm
    http://www.proapptips.com/shane
    USING NON-STANDARD CODECS IN FCP
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Brian Maffitt
    January 16, 2007 at 6:57 pm
    Looks great! Except it’s not working for me… I’ll get back to you after I pound on it a little more…
    I get an error saying that I cannot nest a sequence with a different time base.
    Brian
  • Shane Ross
    January 16, 2007 at 7:21 pm
    Are you following it EXACTLY? Because once you do it, it creates a sequene with your footage already in it.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Brian Maffitt
    January 16, 2007 at 7:34 pm
    I updated my FCP and it works perfectly. Thanks so much! This is a GREAT tip.
    Brian
