Activity Forums Avid Media Composer Editing a rendered motion effect
  • Editing a rendered motion effect
    Posted by Guy Handelman on December 5, 2011 at 7:45 pm
    Is there a way to edit a motion effect that has already been rendered? For example, a 4 second clip has been sped up to 2 seconds. I still think the 2 second clip is too slow, so I want to edit it to 1 second. Is there a way to speed the 2 second clip by 200% or do I have to go back into the old bins, find the 4 second clip, and speed it up by 400%?
    John Pale replied 14 years, 9 months ago 3 Members · 2 Replies
  • Shane Ross
    December 5, 2011 at 7:54 pm
    Gotta modify the main clip. So need to go searching…just Match Frame in the timeline, then Match Frame in the Preview Monitor. It’ll load the main clip
    Shane
    Little Frog Post
  • John Pale
    December 6, 2011 at 4:12 am
    Just promote the clip to a TimeWarp Effect in the Miotion Effect Editor. Then you can change the speed in the Sequence all you want without going back to the bin.
