Activity Forums VEGAS Pro Editing a 30.00 fps file – render options?
  • Editing a 30.00 fps file – render options?
    Posted by Sam Renkin on January 10, 2021 at 5:15 pm
    Several of my clients are now using webinar apps to “pre-record” sessions that need minor editing. The files are true 30 fps (NOT 29.97). Vegas 15 Pro does not seem to have any output settings at 30.00 – should I just select 29.97 and tick the “allow source to adjust frame rate” box in the customize template window? Thanks!
    Graham Bernard replied 5 years, 8 months ago 2 Members · 4 Replies
  • Graham Bernard
    January 10, 2021 at 9:44 pm
    When you do the Match Settings to Media, does your Project show 30fps?
  • Sam Renkin
    January 11, 2021 at 3:41 am
    Yes – I match the media file when I set up the project, and it shows 30.000p as the frame rate.
  • Graham Bernard
    January 11, 2021 at 5:31 am
    Good! It’s good to be picky with this stuff so now let’s be doubly sure by getting the MediaInfo through MediaInfo.
  • Graham Bernard
    January 11, 2021 at 5:59 am
    I opened VP15. I made a Generated Media 30fps Project. Yes I NEEDED to create a 30fps Render To Template. I rendereed this out and confirmed its status through MediaInfo.
