Activity Forums Apple Final Cut Pro Legacy EDITING 24P CANON 5D FOOTAGE WITH 50i JVC HM 100 FOOTAGE
  • EDITING 24P CANON 5D FOOTAGE WITH 50i JVC HM 100 FOOTAGE
    Posted by Kate Parkinson on January 19, 2011 at 4:32 am
    Hello members,
    I’ve been reading these forums for a while now and have always found them very helpful.
    I’m struggling to find the answer to my curent dilemma though so decided to post for the first time.
    I’ve been shooting on the JVC HM100 (1980×1080 50i) for a while now and find the work flow into FCP very easy. But I’ve just stating shooting video with a Canon 5d Mark 11 (1980×1080 24p) and am having problems editing shots from the two cameras together.
    In hindsight I wish I’d not gone for the ‘film look’ on the 5D and had set it to 25p as this might have avoided a few of the problems I’m facing now. Hindsight really is a wonderful thing!
    But for now I’m stuck with the problem of needing to edit the footage from the two camera together.
    Does anyone have any advice on…
    – How I should set up FCP?
    – How I should convert the 5D footage using Mpeg streamclip before I start to edit.
    I need this to be broadcast quality and at the moment it is far from that. Any help would be much appreciated.
    K
    Anthony Bari jr. replied 15 years, 7 months ago 2 Members · 1 Reply
  • Anthony Bari jr.
    January 19, 2011 at 3:01 pm
    You can use both frame rates in the same timeline, FCP has an open Format Timeline for the last few versions.
    You will notice the difference between cameras, but you can use some of the 50i footage to conform to
    slowmotion when needed. 25/24p is going to look alot smoother in realtime, VS the video look of the 50i
    If you dont already have the Canon E-1 Plugin makes sure to download it.
    https://www.usa.canon.com/dlc/controller?act=GetArticleAct&articleID=3249
    Then you can transcode it in FCP via Log and Transfer window, I know the HM100U is the easiest to work with. Right off the card, with the Canon DSLR’s you will need to change these files from H.264 to Apple ProRes. Apple ProRes LT seems to be the favorite for the data rate and file size. Still looks pretty crisp, but you will be blowing up your files by 50%.
    In short, you can work with both the 50i and 24p footage in the same native if you have at least FCP6
    Here is a link that might help in your venture
    https://vimeo.com/6077846
    hope this helps.
    *Production*Post-Production*
    Apple Certified Instructor (Final Cut Pro 7)
    “Semper Fi USMC”
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
