Activity Forums Apple Final Cut Pro Legacy Editable MP4/MOV?
  • Editable MP4/MOV?
    Posted by Jeremiah Stephens on December 29, 2010 at 1:45 am
    I converted all of my WMVs to MP4 with Total Video Converter, but I can’t edit with them on FCE, because the files are too laggy to edit with!
    Is there a better converter I can use that will convert and bulk without lagginess in Final Cut?
    Rafael Amador replied 15 years, 8 months ago 3 Members · 3 Replies
  • Zane Barker
    December 29, 2010 at 4:18 am
    mp4 files are not a proper editing codec in FCE or FCP
    The only codecs that FCE is compatible with are DV and Apple Intermediate Codec.
    **Hindsight is always 1080p**
  • Jeremiah Stephens
    December 29, 2010 at 11:41 pm
    And what tool can I use to convert to AIC that won’t make the file size too big? I tried MPEG streamclip, and the file was 1gb for DV, and there wasn’t an option to convert to AIC 🙁
  • Rafael Amador
    December 30, 2010 at 1:07 am
    Hi Jeremiah,
    AIC has a similar data rate than DV.
    Is around 12/13 GBs per hour.
    To work with the WM files you will need to install “Flip4Mac”.
    With that QT Component installed, you can open the WM files on any QT application (FC, QTPlayer,..), I guess on FCE too.
    Rafael
    http://www.nagavideo.com
