Activity Forums Apple Final Cut Pro Legacy Edit to Tape Question (Error-Tape Write Protected)
  • Edit to Tape Question (Error-Tape Write Protected)
    Posted by Carolina Cid on December 27, 2007 at 2:58 pm
    This may be a stupid question, but I am trying to black and code a tape to output a video to digibeta in FCP. I have done this many times and don’t know why I am getting this error. I am outputting to a digibeta tape from FCP through the KONA 3 to a Sony DVW-M2000. Everytime I try to just black and code the tape FCP tells me that the tape is write-protected. I thought maybe it was the tape I was using but have tried several other brand new tapes and am still getting this error. Can someone explain why I am getting this error? The sequence settings match the output settings, so what am I doing wrong?
    Thanks! 🙂
    Carolina Cid replied 18 years, 8 months ago 2 Members · 2 Replies
  • David Battistella
    December 28, 2007 at 9:30 pm
    You could have the record inhibit switch on the deck enabled.
    You could have the record inhibit tab up on the tape.
    This is a start.
    David
  • Carolina Cid
    January 2, 2008 at 9:25 pm
    Thanks. The record inhibit switch was turned on for some reason on the deck. I feel like a ding-dong now. ^_^
    I have no idea how it happened but now it’s working fine. I never mess with the settings on the deck but someone must have done it!
    Thanks again!
