Activity Forums Apple Final Cut Pro Legacy Edit to tape not working
  • Edit to tape not working
    Posted by Chris Poisson on May 27, 2009 at 11:46 pm
    I feel really stupid about this, as it has happened before and I’ve fixed it, but I don’t remember how. I have a Kona LH on a G5 PC with 4.5 gigs of RAM, running a Firmtek 2 tb RAID 0 SATA array. FCP Studio 2 latest everything.
    I tried trashing prefs and whatnot but still the Edit to Tape is greyed out. Yes, I have the RS422 cable hooked up to my UVW1800 deck. And all the Kona connections are working.
    Have a wonderful day.
    Chris Poisson replied 17 years, 4 months ago 7 Members · 9 Replies
  • 9 Replies
  • Walter Biscardi
    May 27, 2009 at 11:53 pm
    The deck is in Remote?
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Richard Sanchez
    May 27, 2009 at 11:54 pm
    Are the edit to tape functions greyed out? More information would help. Are you running blackburst to the deck, and if not, are you looping your composite signal through the Ref in the on the deck.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Josh Olenslager
    May 28, 2009 at 12:00 am
    Last time I had a similar problem, I reselected my user set-up — I was working HD to Letterbox 4:3 downconvert via Kona — created a new sequence, copy/pasted the edit into the new sequence, and then the edit to tape function started working. All my set-ups were right in the first sequence, but it seemed like it just need a refresh or kick-start. Funky for sure.
    Josh
    Digital Media, Thought Equity Motion
  • Dennis Leppell
    May 28, 2009 at 2:15 am
    just an off the cuff thought, but check the log/capture, make sure it’s not set to non-controllable device, and check the box next to video in the ? tab (shooting from memory, i believe it’s the middle tab).
  • Dan Marlow
    May 28, 2009 at 12:13 pm
    Another thought. Have you dragged the sequence into your source monitor? As an Avid man, this caught me out before.
  • Chris Poisson
    May 28, 2009 at 3:25 pm
    Good thoughts all, will check later today. Ended up just making my dubs from the timeline, there is a 2 pop on the show so hopefully the stations will put up with this, they have in the past before I knew how to use ETT.
    So thanks.
  • Chris Borjis
    May 28, 2009 at 3:59 pm
    Hey chris, I got weirdness once from edit to tape with my kona
    LH as well.
    delete the kona prefs file, then it should reset it.
  • Chris Poisson
    May 28, 2009 at 7:58 pm
    Hey Chris,
    Yes, I think that fixed it the last time, will try.
  • Chris Poisson
    May 28, 2009 at 11:16 pm
    Trashing the AJA prefs did not fix the problem.
