Activity Forums AJA Video Systems edit to tape issues
  • edit to tape issues
    Posted by Kylelynch on August 30, 2006 at 7:24 pm
    I am running FCP 5.1.1, Kona 3 with all the breakouts, Mackie 1402, G5 and Sony UVW-1800 Beacam SP. I ned to do two things that I am unable to. I have all conections and cable runs correct, I hope. I can captue audio/video beautifully from the VTR. I cannot print to tape or edit to tape. I get no timecode, audio levels, nor am I getting anyhing on the tape at all. Just black wih lines and no sound. I also need to do voice over into FCP, and I get no mic audio from Kona 3. I can plug into the Mackie and hear it. What’s the deal with this?
    The best part of you is when you dream, awake!
    Henry David Thoreau
    Christopher Tay replied 20 years ago 2 Members · 1 Reply
  • Christopher Tay
    August 31, 2006 at 12:52 pm
    If you feed the video & audio out from the Kona 3 to the VTR, put it to E/E mode, are you able to get any signal ? If you can, then it confirms the video & audio connection is ok. If not, check again.
    -chrispy
