Activity Forums Apple Final Cut Pro Legacy Edit to tape issue
  • Edit to tape issue
    Posted by Amit Ghildiyal on May 4, 2009 at 9:21 pm
    This is my first time editing a sequence to tape. FCP to DIGIBETA
    sequence: dv/dvcpro NTSC, 29.97, codec:dv/dvcpro ntsc
    a/v settings blackmagic ntsc, decklink audio
    I have followed all procedues , recorded a few minutes of blank and the rew the tape before Assembling it. I have encountered two issues.
    1) Initially the tape recorded the timecode but when i played it back there was no audio or video, although the tape ran for the duration of the in/ out points.
    2) After several attempts, now when i i try it, FCP gives me an error that “end of tape encountered” and the VTR will not even record. The fast forward button on the VTR switches on and off a few times and then I get this error.
    My point is….HELP :-
    Michael Gissing replied 17 years, 4 months ago 4 Members · 5 Replies
  • Victor Perez
    May 4, 2009 at 9:48 pm
    What timecode did you record to on the tape?
    What timecode are you telling edit to tape to start at?
    Does the timecode on the tape go past the number you set as your IN on the Edit To Tape window?
    If the tape is FF and then you get the error can’t find TC on tape, FCP is not able to match the timecode IN to the timecode on your Digi Beta tape.
    hope that helps,
    Victor
  • Amit Ghildiyal
    May 4, 2009 at 10:32 pm
    its is a 30 min tape
    when rewound its on 00:58:34:14
    my in point is 00:58:40:00
    So dont knw whats going wrong. Kindly help
  • Josh Olenslager
    May 4, 2009 at 11:23 pm
    Sorry Victor, I meant to address Amit.
    Josh
    Digital Media, Thought Equity Motion
  • Josh Olenslager
    May 4, 2009 at 11:39 pm
    Victor,
    generally I give myself a bit more pre-roll than 5 1/2 seconds, but you can set your pre-roll needs in the “user preference” setting pane–editing tab. Maybe you’ve got your setting at 10 seconds or something. Switch it to 4 or 5 and see if the VTR will pickup the TC.
    Josh
  • Michael Gissing
    May 5, 2009 at 12:37 am
    Lots of potential issues here. Firstly you have a DV sequence and a Blackmagic card. I assume you have selected the correct Blackmagic DV Easy Setup which gives you an SDI output from the card into the digi beta and RS422 machine control.
    If so, can you see your Final Cut output looping through the digi beta deck? If yes, then do you have common reference video going to both the digi beta and the Decklink card? Next,is the digi beta setup to reference the input signal or the reference signal?
    Finally is the assemble editing picking up during the timecoded pre black section. Also the timecode needs to be setup correctly although it sounds like you have problems back in the SDI and reference area. Lets solve them first.
