Activity › Forums › AJA Video Systems › Edit To Tape inserts first frame twice.
  • Edit To Tape inserts first frame twice.
    Posted by Alexander Serpico on November 1, 2007 at 5:19 am
    Two 3.0GHz Quad-Core Intel Xeon
    8GB (4 x 2GB) RAM
    Kona 3
    OSX 10.4.10
    Final Cut Pro 6
    SONY DVW-A500 DIGIBETA
    Codec: UC 10bit and DV (only tried the two)
    Capture/Render scratch is the internal drive
    Brand new machine. On ETT insert, FCP lays down the first frame twice but then continues as usual. I was testing my new intel machine and kona card, with both a time code generator/then reader filter off a short (under 30 seconds) piece of footage. After 5 attempts, every time the first frame doubled and then proceeded.
    This is potentially a major problem. Anyone else come across this issue?
    Jeremy Garchow replied 18 years, 11 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    November 2, 2007 at 4:20 pm
    Have you talked to AJA about this?
  • Alexander Serpico
    November 6, 2007 at 11:01 pm
    It was set to mastering on this machine (which it never was on my previous box). AJA responded with suggestions of adding an offset (which would not be a fix), and switching to editing in ETT.
    Switching to Editing worked.
  • Jeremy Garchow
    November 6, 2007 at 11:12 pm
    That’s it. I always have Editing set on ETT.
    Good find and thanks for the follow up.
    Jeremy
