Activity Forums Apple Final Cut Pro Legacy Edit to Tape in FC7, Blacking Tape can’t select Drop Frame Checkbox
  • Edit to Tape in FC7, Blacking Tape can’t select Drop Frame Checkbox
    Posted by Travis Marshall on October 6, 2010 at 2:11 pm
    When I try and black a tape, either through Firewire or through the Kona LHe, I cannot select the drop frame checkbox when I enter my starting timecode. When I manually enter a starting timecode in drop frame 58:00;02, Final Cut automatically changes it to 58:00:00.
    My sequence is in drop frame, and my device control preset is set to drop frame.
    I’ve trashed the preferences, and I’ve re-installed Final Cut as well. The problem persists.
    Any ideas out there? Thanks for your help!
    Jeremy Garchow replied 15 years, 11 months ago 3 Members · 3 Replies
