Activity Forums Apple Final Cut Pro Legacy Edit to Tape HELP
  • Edit to Tape HELP
    Posted by Dan Mott on March 25, 2009 at 3:07 pm
    Does anyone know the best way to get a project to a Mini DV tape using a Sony HDR-FX1, and still keep broadcast quality?
    I have my “VCR” mode on the camera set to DV, and I am working with an HD 1440 x 1080 project file. In the past I have tried “Print to Video”, however it seems to really compress the file, and lose a lot of quality. I was recently told Edit to Tape would be the best way to go. When I go to Edit to Tape, I get a message that reads:
    “Incompatible compression settings”
    I think I understand why, because I am using HD footage going to DV, but I have no idea what settings to use. If anyone knows an easier process to this, I would really appreciate the help. Thank you very much!
    Dan Mott replied 17 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    March 25, 2009 at 4:02 pm
    In order to record to DV you have to send it DV… so you need to down convert your HD sequence to DV NTSC (using compressor or QT Conversion) then import that DV file and print that to your DV tape from a DV sequence.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Dan Mott
    March 25, 2009 at 4:35 pm
    Jerry Thank you very much!! That really helped. I appreciate it!!
