Activity Forums Apple Final Cut Pro Legacy edit to tape 4:3 (16/9)
  • edit to tape 4:3 (16/9)
    Posted by Patrick Aubry on September 18, 2008 at 1:47 pm
    hi, I’m editing a show in 4:3 (720,486), the rushes are in 4:3 16/9 , I’m wondering how to output and keep 4:3 16/9 on tape ?
    my sequence is set 4:3 (widescreen)
    I use Aja IoHD to make the edit
    Thank u for your help
    patrick
    Rafael Amador replied 18 years ago 2 Members · 1 Reply
  • Rafael Amador
    September 18, 2008 at 3:48 pm
    If you want the 16×9 pictures to fill the whole 4×3 frame, the only way is to blow your picture up. You will loose part of your picture off course. if you want to show the full picture, letter-boxing is the only solution.
    rafael
    http://www.nagavideo.com
