Activity Forums Apple Final Cut Pro Legacy edit to tape
  • Posted by Slasher5312 on September 5, 2007 at 8:16 am
    I apologise for the newbie nature of this question but this is the “basics” forum so here goes!When I atempt to Print to tape I get the error message “incompatible compression settings” you may have attempted to output a clip with compression settings that do not match the current output settings try nesting the clip in a sequence with the correct settings” I am using the Sequence Preset AJA kona 3 625/25 8 bit and this matches the Audio/Video playback settings, I am using FCP6 KONA 3 Digibeta and working in PAL SD, the capture and VTR control is working fine! Thank you in advance for any help!
    Slasher5312 replied 19 years ago 2 Members · 2 Replies
  • Dunwoody Lampton
    September 6, 2007 at 10:07 pm
    Why not just play the tape out from the timeline?
  • Slasher5312
    September 7, 2007 at 7:37 am
    I could do that, as print to video works fine, it’s just that I need the ability to insert edit the tape and also I need the items I am editing to start at a uniform timecode.I cant do thes things until I get this edit to to work!
