Activity Forums Adobe Premiere Pro edit problem
  • edit problem
    Posted by Pjoconnell on March 3, 2006 at 6:39 am
    Okay: I’m not doing a lot of editing, so I can’t remember all the niceties all the time, but I have a project to finish and a problem I’d like to solve.
    I need to do a series of split edits (J-cut; leading audio). I’ve not mastered the rolling edit tool. I’ve used splits frequently in 16mm editing where I would mark sync on workprint and mag track, make the pix edit, and pull the track up to match. I’ve tried that in PPro: razor at pix edit point, unlink pix and audio in the leading portion of the clip, delete the leading pix portion, move the leading portion of the audio track ahead a good bit, pull the remainder of the clip (linked pix and audio) up to the edit point, and move the leading portion of the track back into sync. Awkward, I know, but it should work. The problem is that I can’t move the leading portion of the audio track ahead. In fact, that portion won’t respond at all; won’t highlight, won’t move, won’t delete. In a few cases where the preceeding scene is a graphic I can stretch the graphic to cover the leading audio, but that’s not going to work every time — and there are a lot of edits.
    Any thoughts?
    THNX/PJO
    Pjoconnell replied 20 years, 6 months ago 2 Members · 4 Replies
  • Craig Howard
    March 3, 2006 at 7:42 am
    ALT KEY – DRAG Head or Tail of Audio or Video part of clip.
  • Pjoconnell
    March 3, 2006 at 7:19 pm
    I tried your suggestion; it didn’t work.
    Now I have an additional(?) problem:
    Neither audio track responds to the mouse. I can’t select, move,
    or delete any audio track clip. I’ve changed track targeting,
    toggled track output, tried everything else that seems at all
    reasonable, but nothing works. I can Undo and reInsert or Overlay,
    but that’s really awkward and it’s useless away from the immediate
    working area.
    I really need a solution; I’m trying to get this piece out. Any
    thoughts/suggestions? I can reload PPro if that would help, but if
    I’ve just missed (or screwed up) a switch that I’m not familiar with,
    that would be easier.
    Help needed/appreciated.
    THNX/PJO
  • Craig Howard
    March 4, 2006 at 6:35 am
    What does the manual / help file suggest for a J or L cut (Do that)
    BTW: I use it (as per my post) and it works fine.
  • Pjoconnell
    March 5, 2006 at 10:08 pm
    I’ll check your suggestions as I have time altho I’ve developed a
    couple of work-arounds.
    Let me repeat my newest problem:
    working area.
    THNX/PJO
