Activity › Forums › Adobe After Effects › edit keyframe while at different time
  • edit keyframe while at different time
    Posted by Andy Engelkemier on June 10, 2011 at 12:37 pm
    I can double click the keyframe, put in a value, hit enter and check my results, but you have to do that over and over by trial and error.
    Is there a way to edit a keyframe, say at frame 0 but have the time slider at say frame 35?
    I know if you have an object and want to move it while moving all the keyframes you can select all the keyframes and then move it, although I’m thinking I remember that the time slider has to be over at least one keyframe, but not sure.
    Am I missing a trick, or did Adobe just kind of ignore this need?
    Andy Engelkemier replied 15 years, 3 months ago 61,679 Members · 2 Replies
  • Andy Engelkemier
    June 10, 2011 at 2:44 pm
    I must not have been clear. I’m aware that is the way it works, but wondered if I was overlooking a way to override that for certain cases.
    I perfect example is where you already have other keyframes in the start of an animation. Maybe some controlling opacity? So in the beginning you can’t see where something is.
    Later in the animation after a couple seconds you need to see where the object is and control that a bit, but you Don’t want a keyframe there.
    So you have to adjust the first position keyframe relative the the timeline where you are located.
    If you add keyframes all over the place, going back and editing an animation can be a pain, and if you want something to look precise, it’s always best to have as few keyframes as possible.
    So it’s a great feature, but I want a way to tell AfterEffects that I’m editing a specific keyframe while having the timeline in a different location.
    I added it to the wishlist. My suggestion was to have sliders available as well as preview when you double click a keyframe to edit it. Currently when changing items in that window it doesn’t update in view until you hit ok.
  • Andy Engelkemier
    June 10, 2011 at 3:58 pm
    Not everyone is a fan of trial and error. I like to see the results as I change them as much as possible so I’m not billing a client for wasted time fighting with software.
    I understand not everyone does advanced things though, so may not have needs like that. Some people just deal with some basic graphics, text, and video footage, so may not even need anything like that.
