Activity Forums Avid Media Composer Edit Final Cut Pro captured files in AVID?
  • Edit Final Cut Pro captured files in AVID?
    Posted by Mike Johnson on September 4, 2005 at 8:37 am
    A friend of mine digitized alot of files using Final Cut Pro 5, but want to edit the movie on his home AVID Xpress System. (he got a PC)
    Is there some codec you can install on the PC so it can read the FCP codec?
    On the FCP computer there is a AVID codec installed so the FCP can read AVID files, but in a worst case scenario we could set up a batch export of all the files (it’s like over 100 clips) to transcode them into the AVID codec, but I rather not do that if it’s possible to get the PC to support the FCP file format.
    Any suggestions?
    Dom Silverio replied 21 years ago 4 Members · 6 Replies
  • Nick B
    September 4, 2005 at 9:58 pm
    On the Avid just IMPORT the FCP Quicktime movies
  • Michael Phillips
    September 4, 2005 at 11:55 pm
    Keep in mind that the import will lose all original source timecode. You might want to consider exporting a batch log out of FCP, translate it via Avid Log Exhange and recapture.
    Michael
  • Mike Johnson
    September 5, 2005 at 7:41 am
    Timecode doesnt matter.
    Does this require that you have QT installed, or does Avid by default support the FCP file format?
  • Michael Phillips
    September 5, 2005 at 4:16 pm
    If you can open the FCP files in MoviePlayer on the system that has the Xpress DV product, then Avid will be able to import it.
    Michael
  • Nick B
    September 5, 2005 at 10:37 pm
    FCP files Are Quicktime !
    Just select import on the Avid and point to the Quicktime media
  • Dom Silverio
    September 6, 2005 at 4:49 am
    Being QT does not guarantee you the ability to import them in to a PC Avid. You need to check the codec. Not all QT codecs are available in the PC – like DV50 and Apple’s uncompress.
    Also, you may have to go through recompression in order to work with it.
    Usually, batch capture would be a better route – unless working with DV25 material.
