Activity Forums Apple Final Cut Pro Legacy “edit duration is only one frame” insert edit fix
  • “edit duration is only one frame” insert edit fix
    Posted by Steve Covello on December 14, 2006 at 7:34 pm
    I occassionally run into the above error message when doing an insert edit fixit with an in-out section.
    I think I found a workaround but I would like others to test it.
    When invoking the Output to Tape panel, select the Mastering tab and toggle the “in to out” back to the “entire media”, then back to “in to out”. then try it again.
    Anyone have other suggestions or causes for this?
    Steve
    double wide post.
    Kenny Park replied 17 years, 5 months ago 2 Members · 1 Reply
  • Kenny Park
    March 11, 2009 at 12:03 pm
    weevie833: “I think I found a workaround but I would like others to test it.
    When invoking the Output to Tape panel, select the Mastering tab and toggle the “in to out” back to the “entire media”, then back to “in to out”. then try it again. ”
    Unfortunately, that didn’t work for me. What DID work for me was simply moving my In and Out points to different positions.
    I have no idea what’s causing this, but at least I was able to move on.
