Activity Forums Adobe Premiere Pro Edit clip with 20,8 fps in 25 fps sequence and keep audio sync?
  • Edit clip with 20,8 fps in 25 fps sequence and keep audio sync?
    Posted by Johan Andreasson on January 29, 2016 at 12:01 pm
    Hello. I have a problem I can’t get around it seems.
    I’m editing a video of two guys talking. Unfortunately the whole clip is recorded in 20,8 fps (!) for some reason. Now, when I drag the clip into my 25 fps sequence the audio do not sync at all.
    If I’m trying Interpret footage… to 25 fps the clip shortens with 20 seconds so that is no option.
    I have even tried to interpret footage to 25 and then use Speed/Dration to the same length at the original clip but that does not help with the synk either.
    Does any one know what I could do? Any suggestion is much appriciated!
    ~ Johan
    Johan Andreasson replied 10 years, 7 months ago 4 Members · 4 Replies
  • Tero Ahlfors
    January 29, 2016 at 12:38 pm
    Was the video shot on a phone?
  • Chris Wright
    January 29, 2016 at 1:47 pm
    let’s assume that the file is indeed 20.8fps. If you want it to play back in a 25fps comp without speed/duration change, you’ll need to decide how to interpolate the frames. frame blending on or optical flow(which is now natively supported in premiere)
    “Exporting time interpolated media
    The Time Interpolation setting in the Export Settings dialog box (File > Export > Media) allows you to change the frame rate of the exported file by leveraging Optical Flow to interpolate the missing frames.”
    you have to render out to see the optical flow. it won’t playback in the timeline.
    https://helpx.adobe.com/premiere-pro/using/duration-speed.html
  • Jeff Pulera
    January 29, 2016 at 6:52 pm
    The clip may use Variable Frame Rate, which Premiere doesn’t like. Convert the file using HandBrake and then try in Premiere
    Jeff Pulera
    Safe Harbor Computers
  • Johan Andreasson
    February 1, 2016 at 5:48 pm
    Thank you, Hand Break did the job!
    Thanks to all the input…!
    ~ Johan
    ~ Johan
