Activity › Forums › Adobe Premiere Pro › Edit all closed captions at once?
Posted by Martin Strandgaard on February 2, 2014 at 6:52 pmHi guys!
I’m working with Premiere Pro CC, and just recieived a .stl file from an interpreter with translations of a spanish interview. This is my first time working with subtitles so I’m new to “Closed Captions”. It works fine the only issue is that I have to change the aperance of the text and this is quite time-consuming since it is an interview with almost 100 captions.
My question:
– Is there a way I can change the settings for all of the captions at once?Thank you for your time!
Martin
Timothy Lucas replied 7 years, 10 months ago 12 Members · 15 Replies -
Kylee Pena
February 2, 2014 at 7:13 pm.stl files are plain text or rich text, right? Could you open the file in TextEdit and do a find/replace all with the settings you want to change?
For example, if you want to change the font from Arial to Helvetica, you could do find “Arial” and replace with “Helvetica”. Or to change the font size, find “$FontSize = 65” and replace with “$FontSize = 45”. Stuff like that.
You could do a more complex find and replace if you have a whole series of adjustments to make.
I haven’t actually done this, but I’ve done a similar thing for changing the color on a bunch of text in an XML file. So please report back if I’m totally wrong.
blog: kyleesportfolio.com/blog
twitter: @kyl33t
demo: kyleewall.com -
Paul Neumann
February 2, 2014 at 8:57 pmI saw a tutorial not too long ago on how to take .txt files into indesign then apply a style to them and export them to PPro. Not terribly complicated, but very useful.
Steve Brame
February 2, 2014 at 9:35 pmHere’s a good start…
https://www.geocities.com/mcpoodle43/DVDMaestro/stl_format.html
If you’re on a Windows machine, you could also take a look at the free tool – Subtitle Workshop. If on a Mac, Jubler Subtitle Editor is good for editing CC and subtitles. Both can read and write the STL format.
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
“98% of all computer issues can be solved by simply pressing ‘F1’.”
Steve Brame
creative illusions Productions -
Steven L. gotz
February 2, 2014 at 10:44 pmYes, but the tutorial was for subtitles, not closed captions.
I think that search and replace using a text editor might be the only way to do this task.
Steven
Steven L. gotz
February 2, 2014 at 10:46 pmMartin,
Please clarify if you mean subtitles (burned into the video) or are you keeping them as closed captions?
Steven
Paul Neumann
February 2, 2014 at 11:07 pmYeah, I saw “spanish” and immediately thought subtitles. Captioning is a whole different beast.
Steve Brame
February 3, 2014 at 12:14 amMany tend to use the terms ‘subtitles and ‘closed captions’ interchangeably, though they are very different. However, if you have STL files, you are talking subtitles. STL is a subtitle format.
Both are editable via most subtitle editors, but as stated, can also be edited in a text editor, as long as you are very careful not to rearrange the structure or accidentally change any format tags while changing the variables of those tags. A ‘Search and Replace’ with a text editor can easily lead to this, while a subtitle editor will prevent it.
Steve Brame
Martin Strandgaard
February 16, 2014 at 10:41 amThank you for your responds!
I am not talking about subtitles (burned into the video) I am keeping them as closed captions.
When I opened the STL-file in both WordPad and NotePad, I got a lot of text, but as far as I could see, there was no way for me to change any propperties of the closed captions.
I just can’t believe that one would have to change every individual caption -
Andy Engelkemier
January 6, 2016 at 9:01 pmOpen the STL with Subtitle Workshop. Export XML. You can now do find and replace. I suggest using Notepad++ instead of notepad. This will arrange formatting easier and make it less likely to accidentally change something. You can do a find and replace All, in one step.
Bring that back into Subtitle Workshop and save as the original format.Otherwise, you’re likely stuck changing each one, one at a time. So I’d just change one the way you want it, then do a find and replace, as you suggested.
Xavier Duke
January 18, 2017 at 10:49 pmHello there! Were you able to get a solution to this? 3 Years later im having the same issue. Need to change the format of a bunch of captions. Any idea?
