Activity › Forums › Adobe Premiere Pro › Edit all closed captions at once?
Timothy Lucas replied 7 years, 10 months ago 12 Members · 15 Replies
Aziz Mughrbi
February 9, 2017 at 12:49 amSeems like no one does. I just finished about 200 lines manually. It’s so dumb, they should fix that soon.
Daniel Tkach
June 26, 2017 at 5:39 pmClick on the first caption or subtitle while on the subtitle or captions editor, HOLD SHIFT, click on the last one, go change the settings (fonts, backgrounds, etc)
You are welcome ☺I just registered to answer this haha I hope it helps.
-Daniel
Andreas Kiel
June 27, 2017 at 10:36 pmJust to clarify:
Files of type .stl files can be either binary EBU.stl which are used as CC source or it can Spruce Text List.stl which are used on DVD Studio and other authoring system.
Latter are text files, for EBU ones you need an editor app for this kind of binaries – I don’t know any on the Mac.
AND you can’t import Spruce Text List.stl into PPro.– Andreas
Spherico
https://www.spherico.com/filmtools“He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil -
Sherry Mutschall
July 19, 2017 at 8:03 pmThis did not work for me. “Select All” does not work. Holding down shift key does not work.
Timothy Lucas
November 19, 2018 at 3:43 pmShift-selecting does work but not in the timeline — you have to do it in the Captions panel and edit there.
