Activity › Forums › Adobe Illustrator › edit a TTF font in Illustrator
  • edit a TTF font in Illustrator
    Posted by Harry Hoag on June 17, 2009 at 2:39 pm
    I need to edit the vectors of a TTF font that i have, can i do this in illustrator? i’ve had a look but nothing is jumping out at me…
    can this be done?
    H
    Harry Hoag replied 17 years, 3 months ago 2 Members · 2 Replies
  • Norman Greenwood
    June 17, 2009 at 6:28 pm
    If you are actually trying to edit a font in Illustrator, I don’t think you’ll have much luck as you won’t be able to export it as a TTF from what I understand.
    I do know that CorelDraw allows the exporting of TFF files, you may be able to edit the vectors in there without a problem…
    What might be best, if you already have Illustrator, is to also get the program Fontographer (https://www.fontlab.com/font-editor/fontographer/).
    You can work in Illustrator, export it as a EPS file, then import it into Fontographer and get your TFF file.
    However, I read one person’s account of the look appearing fine in Fontographer after importing a Illustrator 3 EPS file, then coming out messed up. But then again, this person was working on a Mac, using an old Illustrator file format, and then transferring to a PC. Fontographer has some differentiations when it comes to MAC and PC.
    Hope this helps.
  • Harry Hoag
    June 18, 2009 at 7:53 am
    cool, thanks for your help, i’ll give that a go. But i’ll be doing the same as that other poor hapless fellow, i’ve only got illustrator for the mac.
