Activity Forums Audio Edirol R-09 Sennheiser G1 / Rode lavalier
  • Edirol R-09 Sennheiser G1 / Rode lavalier
    Posted by Ben Edwards on November 28, 2010 at 6:28 pm
    I was wondering of the lav microphone from the Sennheiser G1 (I think it is the same connecton as G2/G3) will work with Edirol R-09? Alternativly will the Rode lavalier work with the R-09?
    Ben
    Ben Edwards replied 15 years, 8 months ago 3 Members · 5 Replies
  • Eric Toline
    November 29, 2010 at 3:17 am
    Only if there’s 3-5vdc available at the mic input of the recorder. Try it and see. One thing is for certain, there’s no 48v phantom available there.
    Eric
  • Ben Edwards
    November 29, 2010 at 11:15 am
    Eric,
    are you sure this will not damage microphone/Edirol?
    Ben
  • Eric Toline
    November 29, 2010 at 1:52 pm
    Yes I’m sure there will be no damage as long as the mic is plugged into the 1/8″ mic input. The 3-5vdc at the mic input is exactly the same voltage that a wireless transmitter provides to power the lav. Are you going to use the lav hardwired without a wireless system?
    Eric
  • Guy Cochran
    December 3, 2010 at 2:36 am
    You can absolutely use small lavs such as the ME2 and RODE lav with the Edirol R-09. I’ve also used my Countryman B6 with the Edirol R-09 and Edirol R-09HR. You just need to turn on plug-in power for it to work.
    1 Press and hold down the FINDER/MENU button until “Menu” is displayed. 2 Cursor down to “Input Setup.” 3 Press the REC button. 4 Cursor down to “Plug-in Power.”
    5 Press 4 to turn plug-in power on if it’s not already on. 6 Press the FINDER/MENU button twice to return to the main screen.
    The new RODE lavalier works very well. I just tested it with an inexpensive new recorder that is giving the Edirol R-09HR a run for it’s money, the new $99 Zoom H1. You can hear the test here https://www.dvestore.com/news/5/RODE-Lavalier.html
    I like the RODE lav because I can use with my Sony PCM10, the H1, my Sennheiser G3 or plug it directly into my mixer with the XLR micon. If you get a Micon for the RODE lav, make sure it’s a Micon 2 as the 1 is also 3.5mm, but is locking and doesn’t quite go down all the way on a portable recorder. The Sennheiser ME2 stock lav supplied with the wireless should recess enough for it to be plugged into a recorder.
    Guy Cochran
    DVcreators.net – DVeStore
  • Ben Edwards
    December 26, 2010 at 4:41 pm
    Thanks a lot for this, just ordered the adapter.
    Happy Christmas,
    Ben
