Activity › Forums › Adobe Premiere Pro › Ediing R3D files between Premiere and FCP and back to Premiere
  • Ediing R3D files between Premiere and FCP and back to Premiere
    Posted by Brian Palmer on January 13, 2013 at 11:43 pm
    I’ve been editing in Premiere now we need to bring another editor in to meet a rush deadline. He can only use FCP. If I export an XML will he have to transcode the footage to Prorez? if he sends me back a sequence done in FCP can I use that sequence even though it may have been cut with Pro-Rez files?
    Many Thanks in advance!
    Angelo Lorenzo replied 13 years, 8 months ago 3 Members · 2 Replies
  • Shane Ross
    January 14, 2013 at 7:05 pm
    My advice…don’t try to mix NLEs. It’s more of a headache than you think. More time will be spent trying to get the footage and sequence back and forth than actual creative cutting.
    Why can’t they use Premiere Pro? There’s a free 30-day demo. Beyond that you can use the Creative Cloud and pay for the app on a monthly basis. And if you use the FCP keyboard layout, it’s almost exactly like FCP.
    If he can ONLY use FCP…than he’s a very limited editor who will find it difficult to find work. IF he can’t use PPro…find someone who does.
    Shane
    Little Frog Post
  • Angelo Lorenzo
    January 14, 2013 at 10:02 pm
    I agree with Shane, if he wants the job then he should know Premiere or find another editor who does.
    If I recall, Final Cut will wrap the r3d files to MOV and will be able to read them with RED’s plugin, no conversion needed. With that said, conforming will be a bit of a headache because you have an XML that will have “.mov” as the file extension. Prepare do a little conform work in Premiere as edits are being brought back into the system. It’s a hassle but at least both systems should be using the same clip timecode; it’s not an impossible task.
    Is this FCP7 or X? If it’s X then you need a kind of pricy conversion tool for the XML file it spits out that no one cares to be compatible with.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
