Activity Forums Adobe After Effects Echo effect WITHOUT the echo effect
  • Echo effect WITHOUT the echo effect
    Posted by Dolph Kawalec on March 30, 2022 at 5:17 pm
    Hi, I’m trying to develop a simple animation to be converted to a .json file with Bodymovin. The problem is that it uses the Echo effect, which does not translate through Bodymovin. Is there a technique to make the motion trails effect without using any effects? Any help would be appreciated. Thanks!
    Walter Soyka replied 4 years, 1 month ago 2 Members · 1 Reply
