Activity Forums Adobe After Effects Echo Effect not working in AE 7
  • Echo Effect not working in AE 7
    Posted by David Cohen on October 15, 2007 at 8:25 pm
    Hey guys,
    quick question here – I built a comp in 6.0 using echo. When I try to open the comp in any version newer than 6.5 the echo effect does not work.
    Is this not supported? Is there a switch I am forgetting?
    Thanks all.
    Cheers
    -Dave-
    Aharon Rabinowitz replied 18 years, 11 months ago 2 Members · 1 Reply
  • Aharon Rabinowitz
    October 16, 2007 at 2:11 pm
    In some cases, effects get updated and then things don’t work quite right in the new version if you open an older file. It just happened to me with CC rain the other day.
    My suggestion is to write down the settings you had, delete the old effect, and then add in the effect again.
    Or you can just try playing with the settings to see if any changes you make fix the problem.
    Aharon Rabinowitz
    arabinowitz(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
