echo effect, force motion blur and mask combo issue
Gentlemen,
I am trying to get the following effect:
In AE7, I take a still image, rotating into the comp 90 degrees, with an echo effect so it looks a bit like a fanned out stack of cards. When I use Force Motion Blur, I lose my echo, so I precompose and add the Force Motion Blur to the precomp to get the desired look. So far so good.
Since the edge of the original image is harsh on top of the blurred deck underneath after the still has completed the rotation, I add a blur around the edge of the original still (using adjustment layer and mask). But if I look at the final result of the nested comp, instead of the blurry edge around the still, i see the mask contour/outline in the still.
Any insight on this would be appreciated… is this a bug ?
( BTW, When I collapse transformation, I loose the echo again…)Thanks in advance
Adrian
