Activity Forums VEGAS Pro Easy way to split 1 movie to small clips?
  • Easy way to split 1 movie to small clips?
    Posted by Scott Wright on August 16, 2006 at 9:20 pm
    Hi There,
    I have just got footage from a client (around 2hrs) and is in a single movie file. I normally like to scan the footage and trim the timeline down to small “chunks” that I want to use in the final edit (only 4mins long)
    Before I simply keep all on the timeline and just drag into place, but this can be quite time consuming. Is there an easy way I can store these ‘clips’ I have made, which are essentailly crops off 1 file and save them in the project media library? Im not sure if the trimmer does something along these lines,
    Thanks for any help in advance!
    https://www.scottswork.co.uk
    Scott Wright replied 20 years ago 2 Members · 2 Replies
  • George Wing
    August 16, 2006 at 9:41 pm
    When you go to save your project, there is a checkbox option under the “Save as type” — it is “Copy and trim media with project”
    NOTE: it stores the video and audio as separate streams
    Regards,
    George
  • Scott Wright
    August 16, 2006 at 9:45 pm
    ah ha, I have just found what i was looking for, right click the file and select CREATE SUBCLIP, that does precisely what I was after!
    thanks george for your reply anyway
