Activity Forums DaVinci Resolve Easy way to share entire project worth of grades?
  • Easy way to share entire project worth of grades?
    Posted by Steve Kennedy on May 21, 2015 at 1:20 pm
    I understand you can easily share the grade for a single shot by exporting a still (DPX / DRX). But if someone has an entire project, with many hundreds of shots, is there an easy way to share those without having to export each shot individually? Is there just a way to share the project?
    S
    Ali Quintana replied 11 years, 3 months ago 4 Members · 4 Replies
  • Vincenzo Onorato
    May 21, 2015 at 3:14 pm
    Hi Steve, you could try in this way:
    grade your project
    save all stills from first or middle frame
    copy all stills in folder
    create a new power grades album
    paste all stills
    export the entire project + an XML/AAF/EDL
    Be sure that the saved stills contain all nodes at each level (timeline, pre-clip, post-clip)
    V.
  • Joseph Owens
    May 25, 2015 at 5:43 pm
    File:
    Export:
    Project
    Save to /folder/directory (include stills?)
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Steve Kennedy
    May 25, 2015 at 6:11 pm
    Ha, yes. It really is that simple. I seem to remember using an older version of Davinci where it was much harder to share projects, but perhaps I was mistaken even then.
  • Ali Quintana
    May 25, 2015 at 11:15 pm
    OK, thats a great way, is there also a way to archive all the footage used?
    Like archive a folder with the Davinci file and all footage?
