Activity Forums Adobe After Effects Easy way to repeat Clock Wipe every second?
  • Easy way to repeat Clock Wipe every second?
    Posted by Luke Mcfadden on October 28, 2010 at 6:07 pm
    I’m making a simple countdown timer, using Clock Wipe on a solid layer to visual show time passing (I’ve also got a numerical countdown as well). I’ve got the transition completion keyframed properly for one second, or one completion. Whats the easiest way to reproduce this effect for each second? I’m only doing a 60 second countdown.
    L
    Todd Kopriva replied 15 years, 11 months ago 2 Members · 1 Reply
  • Todd Kopriva
    October 29, 2010 at 6:18 am
    Use the loopOut expression method. Set it to cycle. It’ll repeat a set of keyframes until the Out point of the layer is reached.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
