Activity Forums Apple Final Cut Pro Legacy Easy way to clear transitions?
  • Bret Williams
    June 9, 2007 at 3:47 am
    Yes. It’s the reverse of adding multiple transitions. Put the playhead at the first clip. Make sure you’re patched to edit onto the particular track. Highlight all the clips with the multiple transitons. Drag them to the canvas and over the “overwrite” well that appears. It will edit the shots back onto themselves, but as cuts only.
  • Steve Sy
    June 11, 2007 at 6:12 pm
    Thank you!
