Activity Forums Compression Techniques easiest way to put 320 x 240 web captured video onto dvd
  • easiest way to put 320 x 240 web captured video onto dvd
    Posted by Steve Goldberg on March 13, 2008 at 10:19 pm
    I’ve been asked to capture a live web conference and the size of the webcast will be 320 x 240. I was going to record it with Snapz Pro X in the default animation codec and then use Compressor and one of the DVD settings. I did a test record with this method and it works, but it increases the image size from 320 x 240 to 680 x 480, making it all look a lot blurry. Is there a way I can keep the 320 x 240 size within a 680 x 480 dvd framework? Will I need to take the 320 x 240 QT file into FCP and add black around the edges so it fills to proper DVD dimensions? Can I do this step in Compressor?
    Hope this makes sense,
    Steve
    Rich Rubasch replied 18 years, 5 months ago 2 Members · 1 Reply
  • Rich Rubasch
    March 16, 2008 at 2:22 am
    Hmmm….recording to animation codec will make a really big file. Unless you record to an external RAID with at least Firewire. If you can get a laptop, or computer with video outputs, I have recorded web casts straight to a DVD recorder or DV deck with simple composite video inputs from the computer. Then I could bring that clip into an editor to get it ready for a DVD.
    This is the safest because you are just using the video output of the feed, not actually recording anything to a drive on the computer, or asking SnapZ to keep up for the entire stream.
    Just run your video and audio out to a DV deck or DVD recorder.
    Safe, easy.
    Rich Rubasch
    Tilt Media
