Easiest way to move the video or the audio 10 frames to sync them together?
I have ScreenFlow screen captures that consistently are out of sync by about 10 frames because it’s being first run through Adobe Connect servers. I have 3 of these videos a week that I have to edit, so if I can find a quick fix, that would be great.
As a quick test, I detached the audio and moved it ahead 10 frames, recompiled as a Compound Clip and it’s better. It will never be great because it appears that when run through the Adobe servers it comes back at about 10-20 fps.
1. Would this be easier and quicker to move the video instead of detaching the audio?
2. Should I do this to the main file in the Event Browser before bringing it into a Project? I certainly would want to do it in the beginning of the edit before I make cuts. I guess the advantage of bringing it down to the Project first might be that after cutting off the un-needed footage at the top and end, it would give “handle” space to work with in the Project.
Dave
