Activity Forums Apple Final Cut Pro Legacy easiest way to apply an audio transition to a whole track
  • easiest way to apply an audio transition to a whole track
    Posted by Ben Scott on August 20, 2008 at 9:07 am
    came up this week
    how would you apply an audio transition to all clips in a specific track as you cannot select more than one edit point at a time
    I know the trick with visual transitions where you can drag the visuals to the browser to rededit back in with overwrite and transition, useful for stills.
    my suggestion was use track auto select to only audio track needed, turn off linking, use select edit (v) and then the shortcut for add default audio transition. then use up down arrows to progress between clips and apply again
    alternative I suppose would be go to soundtrack pro and get dragging, quick though and more responsive
    Ben Scott replied 18 years ago 2 Members · 3 Replies
  • Andreas Karoliussen
    August 20, 2008 at 10:38 am
    Hi Ben,
    Use T to select the audio track you want, place your play head and your audio destination (A1) to the same track. Grab your clips in the timeline and drag them into your canvas and over to “overwrite with transition”.
    You can also do this with a part of a track.
    Your default transition is being used so if you want another transition – make the transition the way you want it. Drag it into the Browser and set it do be your default transition.
    Best regards
    Andreas
  • Ben Scott
    August 20, 2008 at 4:14 pm
    thought it was only visuals
    ah well
    thats good
    thanks andreas
    suppose it is good to check clips have proper handles before doing this type of action though and maybe even do it on a duplicate sequence
    from ben
    Check my podcast at https://cowcast.creativecow.net/final_cut_pro/index.html
    or my site at
    https://www.benscottarts.co.uk/ – – – – – – – – –
  • Ben Scott
    August 20, 2008 at 4:15 pm
    ah well
    thats good it does sound (audio transitions) if you unlink first and then select clips needed
    thanks andreas
    from ben
