Activity › Forums › Apple Motion › easiest way to add a glow to a moving object in Apple Motion
  • easiest way to add a glow to a moving object in Apple Motion
    Posted by Kevin Thorne on October 18, 2009 at 1:57 am
    I am using Motion 3.0.2 and need to add a subtle glow to a moving person in several scenes – the only way I have figured it out so far is to cut out the person and move him up to the top layer, then place a duplicate of the cut out below him and add glow to that — but I’ve not been able to figure out how to add an outer glow to a masked layer – it doesn’t show. I can when I use a green screen (I use DVGarage’s DVMatte Blast for that) but not when I create the mask.
    If I could create a path around the person and animate that with them, and somehow add a glow to the outside of that path, that might work….is this possible?
    Is there an “easy” workaround? I have many of these to do and need to get it done the most time-effective way, whilst still giving a good effect.
    thanks in advance
    Arnie Schlissel replied 16 years, 11 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    October 20, 2009 at 1:29 am
    [Kevin Thorne] “If I could create a path around the person and animate that with them, and somehow add a glow to the outside of that path, that might work….is this possible? “
    That’s certainly possible using the Shape tools and animating the spline. You could also rotoscope a color solid over the person, and drop the opacity down very low. Either way, it’s a lot of hand work to rotoscope the effect. I hope the shots are short!
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
