Activity Forums Adobe After Effects easier way of deleting warp stabilizer track points through time.
  • easier way of deleting warp stabilizer track points through time.
    Posted by Jarrick Harris on November 2, 2017 at 1:22 pm
    Hi all,
    When using warp stabilizer, there’s the option of ticking the box to show the track points – so you can scrub through your footage and delete the ones on objects you don’t want stabilized, making the process more accurate.
    However, this is time consuming as, for instance, if you have a moving object in one part of the screen that you want to exclude from being tracked, you have to repeatedly delete tracking points from it as they keep spawning on it further down the time line.
    Does anyone know a way of selecting an area to exclude from tracking for the entire length of the clip?
    Cheers
    Jarrick Harris replied 8 years, 10 months ago 1 Member · 1 Reply
  • Jarrick Harris
    November 3, 2017 at 9:24 pm
    Thankyou very much. That’ll help a lot.
