Activity Forums Apple Motion Ease out of a keyframe after a freeze/pause
  • Ease out of a keyframe after a freeze/pause
    Posted by John Hill on April 9, 2010 at 4:43 pm
    I must be missing something. If I’m panning a photo and want to pause, i usually add a keyframe where i want to stop and then a few seconds later add a copy of the first keyframe thereby creating a pause in my pan. My problem comes next, when I want to very gradually continue my pan. If I interpolate the second keyframe to ease out – the scale parameter does not behave and does not ease out at all – it actually creates a line greater than a linear interpolation. So I use a bezier curve but immediately that nullifies my pause because the bezier curve exists on both sides of the second keyframe. I can try to put the left curve back into the keyframe but that seems like a big headache.
    Is there anyway to keep the gap between the two keyframes rock solid and still have the ability to manipulate the right side bezier curve to yield a gradual ease out?
    Thank you.
    John Hill replied 16 years, 5 months ago 4 Members · 4 Replies
  • Andy Neil
    April 9, 2010 at 5:25 pm
    Sure, use behaviors instead. Use a Move or Motion Path (if the movement is multi-directional) for the movement. Change the speed to ease both, and then trim the behavior to the point where you want a pause. At the end of the pause, add another behavior and continue on.
    Andy
  • Arnie Schlissel
    April 9, 2010 at 5:41 pm
    You can ‘break’ the tangent handles of a Bezier point so that they move independently of each other. I think you just need to right click on a handle for the option.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Stephen Smith
    April 9, 2010 at 7:47 pm
    Lots of great advice, another trick: when you copy the first keyframes or just re generate them move another frame down the time line and repeat. That will have the last keyframe effecting the repeated keyframe and will eliminate your problem. Best of luck.
    Utah Video Productions
    Check out my Motion Tutorials
  • John Hill
    April 9, 2010 at 7:56 pm
    Thank you EVERYONE! I knew there must be a better way. I was going nuts and now I don’t have to! Thanks again!
