Activity › Forums › Maxon Cinema 4D › Ease in individual objects using Plane Effector
  • Ease in individual objects using Plane Effector
    Posted by Glenn Tak on February 10, 2020 at 1:21 am
    Let’s say we have 5 objects dropping to a surface.
    I have 5 objects in a fracture object and run a Plane effector (Y axis only) Linear field across.
    I have added a curve to the remapping so there is an ease out.
    But the ease out only effects the last of the five objects.
    Is there a way to use an effector and have each of the objects ease in to their final resting position?
    Thanks in advance.
    TAK
    ______________________
    “Nothing is Easy”
    Jethro Tull
    Glenn Tak replied 6 years, 7 months ago 2 Members · 2 Replies
  • John Williams
    February 10, 2020 at 12:32 pm
    Hi there, this sounds like you simply need to add a ‘delay effector,’ that will give you some ‘easing’ to the motion of each object:)
    Hope that helps, any questions please reply.
    John Williams
    Soho Editors
  • Glenn Tak
    February 10, 2020 at 4:23 pm
    Thanks John,
    The solution actually came to me in the middle of the night but you confirmed it.
    Appreciate the quick reply!
    TAK
    “Nothing is Easy”
    Jethro Tull
