Activity Forums Maxon Cinema 4D earth core
  • earth core
    Posted by Gareth Wrafter on February 7, 2011 at 4:19 pm
    I want to animate the earths core in cinema 4d but struggling with texturing what seems to be a simple job!
    I want to be able to animate slicing into the earths core with a boolean shape revealing the gradient of colour and the texture stays centralized to the core of the sphere while animating could anyone point me in the right direction to be able to colour/texture the ‘inside’ of a primitive shape?
    Gopal Reghunath replied 15 years, 6 months ago 3 Members · 5 Replies
  • Brian Jones
    February 7, 2011 at 4:44 pm
    on the cutter use a 3D spherical gradient which is centered at the earth’s center. Make sure you set the Gradient’s Space to be World.
  • Gareth Wrafter
    February 7, 2011 at 4:50 pm
    ooh nearly there how would I centre the texture to the earths core if its on the ‘cutter’ shape?
  • Gareth Wrafter
    February 7, 2011 at 5:28 pm
    Done the first parameter on the ‘start’ was defaulted to 100cm changed to zero and all sweet now many thanks for the help once again Brian
  • Gareth Wrafter
    February 8, 2011 at 9:50 am
    also on the boole if I check create single object and use texture instead of world the texture on the cutter becomes the centralized texture on the sphere so I can then animate an orbit and also animate a cut
  • Gopal Reghunath
    February 14, 2011 at 11:56 am
    Hey,
    Even i tried this effect out thanks to you guys. I had used a pyramid with 3 sides as the cutting object. But when i animate the pyramid going in and out, the texture inside changes with the pyramid. How can I make it locked to the same location on the inner side of sphere irrespective of the pyramid movement?
    (I had done ‘use single object’ and used ‘texture’ instead of ‘world’)
    http://www.youtube.com/vertigomaniac
