Activity › Forums › Creative Community Conversations › Early Speed Tets of MacPro 2013
Posted by Michael Phillips on June 21, 2013 at 1:20 pmPaul Dickin replied 13 years, 3 months ago 8 Members · 14 Replies -
Chris Lehmann
June 21, 2013 at 3:48 pmInteresting. As some of the comments on the site point out, this benchmark doesn’t factor in the GPUs. Since Apple has obviously intended this as a FCPX machine, the CPU performance is much less important than it used to be.
I don’t think Apple is attempting to position this as a number-crunching server for scientific and industrial use, as a lot of that market has moved on to Linux based systems.
Gary Huff
June 21, 2013 at 7:32 pmBut you can add more powerful GPUs to the Mac Pro, essentially closing the gap even on that.
Ronny Courtens
June 22, 2013 at 9:40 amSo someone claims they have tested the CPU that is probably going to be one of the CPUs used in the new Mac Pro. “Claims” because this source has not been officially confirmed. “Probably” because this is an educated guess. And to be fair: if this test were indeed official I certainly would not call it a “speed test of the MacPro 2013”, but merely a test of the CPU that will possibly be used in it.
I think we will have to wait for real performance tests until anyone actually has his hands on this machine. Anything else is mere speculation.
On the other hand there are also people who have the capabilities to put “tests” like this into a more realistic perspective, like this reaction from Kyle Russel (Business Insider):
“The new Mac Pro is also extremely power-lopsided: it will initially max out at 12 cores (almost certainly this exact CPU), which is upper-midrange by Xeon standards, but it comes with a ridiculous amount of GPU power. This is overkill to just be about future desktop Retina Displays — clearly, Apple’s pushing for pro and scientific apps to shift more of the heavy lifting to OpenCL. If they succeed, the new Mac Pro will probably crush everything else in its price range (and the rest of the Mac lineup).”
Gary Huff
June 22, 2013 at 1:23 pm[Ronny Courtens] “o someone claims they have tested the CPU that is probably going to be one of the CPUs used in the new Mac Pro. “Claims” because this source has not been officially confirmed. “Probably” because this is an educated guess. And to be fair: if this test were indeed official I certainly would not call it a “speed test of the MacPro 2013″, but merely a test of the CPU that will possibly be used in it.”
It’s not quite that someone is “claiming” it…apparently it’s results that were transmitted back to Geekbench’s servers, and someone noticed that the system identifiers indicated it was more than likely the new Mac Pro (including the fact that Geekbench was being run on a custom build of Mavericks).
Ronny Courtens
June 22, 2013 at 5:01 pmGary you are correct, my bad. This does not alter the fact that calling this a “speed test for the new MacPro” is rather short-sighted as it only shows figures about the presumed CPU. The comparative figures confirm however that CPU speed is indeed slowly reaching its limits and porting processor tasks to the GPU is the way to go. So real performance tests will only be possible once the new MacPro is actually here.
Gary Huff
June 22, 2013 at 5:16 pm[Ronny Courtens] “So real performance tests will only be possible once the new MacPro is actually here.”
I agree, but I also think that, if the CPU isn’t performing more significantly than the one in the current Mac Pro, and given that you can always upgrade your GPU (Mountain Lion supports a significant number of new graphics cards, even though you don’t get any picture without a Mac-based card until you get to the desktop), I’m sure you can significantly close any gap between the two, performance-wise.
Christian Schumacher
June 23, 2013 at 1:43 am[Gary Huff] “I’m sure you can significantly close any gap between the two, performance-wise.”
Today the current Mac Pro can be loaded with two (supported) nVidias Quadro K5000 (without any additional power) and that will add 8GB of VRAM. Let alone 96 GB of RAM (and more on next OS) So, I don’t think it is a simple coincidence that both nVIdia and AMD are releasing video cards engineered for this “old” machine as of lately. There are tens of thousands of Mac Pro machines that will keep on running and steaming a lot more time they initially would. And who knows what else one could cram in a today’s Mac Pro in the near future, considering one could choose from multiple different PC GPUS as well. Here’s an interesting link about this topic that I caught: https://www.marco.org/2013/06/20/new-mac-pro-geekbench
Ronny Courtens
June 23, 2013 at 7:35 amVery interesting points made here. Thank you for the clarifications.
Walter Soyka
June 25, 2013 at 1:50 pm[Ronny Courtens] “The comparative figures confirm however that CPU speed is indeed slowly reaching its limits and porting processor tasks to the GPU is the way to go.”
I respectfully disagree.
The figures show that single-threaded CPU performance is plateauing. Why? Current CPU design aims for speed by getting more cores doing more things in parallel, not fewer cores doing more things in series. This is actually exactly the same way that GPUs seek performance. No matter whether developers choose to target CPUs or GPUs, the current answer for more speed is parallel computing.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Ronny Courtens
June 25, 2013 at 7:19 pmYou have a point there, Walter. I should have said “single threaded CPU speed is reaching its limits” and we agree parallel computing is the way to go. Obviously that’s also the way Apple is going with this machine. That’s why I resent the title “speed tests of the new MacPro” while this is merely a benchmark test of the supposed CPU, not of the complete system.
