Activity Forums Apple Final Cut Pro Legacy e-cinema QT to .mpg best converter
  • e-cinema QT to .mpg best converter
    Posted by John Doggett-williams on May 21, 2012 at 2:08 pm
    I’m trying to find a good quality converter to go from quicktime to mpeg2-ps hd (which ends up as a .mpg). I’m using icoolsoft which can boost the vid bitrate to 20000kbps and audio up to 320kbps. The quality was fine for the e cinema screen but I was curious because the 52minute HDV program shrunk to 4.3gig. I heard the files for that length can be much larger.
    Any suggestions?
    John Doggett-Williams
    http://www.fineeyeproductions.com
    Neil Ryan replied 13 years, 12 months ago 2 Members · 1 Reply
  • Neil Ryan
    May 22, 2012 at 7:51 am
    I can recommend someone local if you want to outsource it and relieve yourself of any headaches.
    Neil.
