Activity › Forums › Maxon Cinema 4D › DYNAMICS quick preview?
  • DYNAMICS quick preview?
    Posted by Emmet Reddy on February 7, 2010 at 11:29 am
    hi when im using dynamics is there a quick way to preview my results i dont mean the render make preview menu but when i apply the effect i have to play all the frames to see the effect but i would like to simply scroll to frame 500 myself and see the result? Is this possible?
    Thanks Emmet
    Emmet Reddy replied 16 years, 7 months ago 2 Members · 2 Replies
  • Jeremy Allen
    February 7, 2010 at 6:08 pm
    The only way I know that you can reliably scrub through a dynamics simulation is by using a Mograph Cache tag. This tag will “bake” in the animation, so you can then go to any frame and see what it would look like at that point. One thing to note though… if you change something about your animation, you need to clear the cache and then re-bake it. If you forget to do this, you will become very frustrated wondering why the viewport hasn’t updated your animation to reflect the changes you just made..
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6
    C4D 11.5
    AE CS3
    FCP 6.0.1
  • Emmet Reddy
    February 11, 2010 at 5:36 pm
    cheers thanks very much
