Activity › Forums › DaVinci Resolve › Dynamics not animating
  • Dynamics not animating
    Posted by Mike Halper on June 8, 2013 at 9:20 pm
    I’m having trouble getting dynamics to animate. It’s a very simple correction with the only changes in the dynamics being the Gain, Gamma, and Lift Y adjustments. Between the keyframes there’s no change and then it jumps to the new setting when it reaches the next keyframe. I’ve tried it multiple times and get the same result. I haven’t had this issue with dynamics before, even when making much more complex adjustments between dynamics.
    I also tried selecting a keyframe, right clicking and selecting Change to Dynamic Keyframe and get an error: Mark Operation. Please select a mark for this operation.
    I’m running 9.1.4 on OS X 10.8.4 (just starting a brand new project). Is this a potential new bug with 9.1.4 where dynamics will no longer animate? Any solutions?
    Paul Provost replied 13 years, 3 months ago 4 Members · 4 Replies
  • Andrew Smith
    June 9, 2013 at 2:47 am
    I just noticed the same today also after those updates were done on my system…pretty basic dynamics with three keyframe animating a shape so it seems like a bug to me.
    Is anyone else noticing strange behavior with dynamics after the latest updates?
  • John Tissavary
    June 10, 2013 at 4:14 pm
    Not having any issues here – just tried ‘start dymanic’ > ‘mark’ as a dynamic dissolve, worked fine. Also did auto keyframe with lift , gamma, gain adjustments, worked fine. Is there a specific sequence of steps I can try to duplicate this problem?
    JT
    John Tissavary | colorist | owner
    The Post Collective
  • Mike Halper
    June 11, 2013 at 1:05 am
    Someone please correct me if I’m wrong, but aren’t the numbers for the settings supposed to update as you move frame by frame along the dynamic?
    When I opened up Resolve today I checked the shots I was having this issue with and they dynamics appear to be working now but the numbers in the interface are not changing until it actually reaches the keyframe.
  • Paul Provost
    June 11, 2013 at 2:49 pm
    Think it’s always been like that
    http://www.4Kfinish.com | owner-colorist | Hollywood, CA
    http://www.facebook.com/4kFinish
    Twitter 4kfinish
