Activity Forums Adobe Premiere Pro Dynamics: Limiter is on -3dB on Premiere CS6
  • Dynamics: Limiter is on -3dB on Premiere CS6
    Posted by Bernhard Walzl on September 23, 2014 at 1:16 am
    Hi!
    I have a long audio file and can’t go thorugh it manually to adjuste the peaks, so I want to put a compressor on it, and limit it off to -0.1 dBFS.
    So when I do so, the limiter is set on:
    Threshhold: -0,1, Release time: 50ms
    However, the audio will not exceed -3dB, although I have set the Threshhold to -0.1dB.
    What is going on here?
    For information, the compressor kicks in at -20dB, Ratio 3:1, Attack 1ms, Release 100ms and my Make up is at 15dB.
    Even when I put a make up of 30, the limiter will limit to -3 and not to 0.1 what I want it to be.
    Thanks for your help.
    Bernhard Walzl replied 11 years, 12 months ago 1 Member · 1 Reply
