Activity Forums Apple Final Cut Pro Legacy Dynamically highlighting a graphic
  • Dynamically highlighting a graphic
    Posted by Ramone Kalsaw on July 21, 2008 at 8:02 pm
    I’m working on a project that requires different portions of a graphic to ‘highlight’ or ‘come alive’ to illustrate points the narrator is making. I’m working with the Chinese symbol for Yin/Yang.
    I was hoping to learn how others would approach this process. For example, as the video progresses I need to make the black and white ‘fishlike’ sections prominent on cue; likewise with the black and white dots within the ‘fish.’
    Any suggestions about’best practices’ for doing this kind of effect?
    Thanks.
    Ramone Kalsaw replied 18 years, 2 months ago 3 Members · 4 Replies
  • Rafael Amador
    July 21, 2008 at 8:39 pm
  • Ramone Kalsaw
    July 21, 2008 at 9:54 pm
    Thank you.
  • Tom Matthies
    July 22, 2008 at 1:31 am
    A simpler way would be to just take the elements into Photoshop and create elements as graphic pieces. To highlight a section of a graphic, simply take that element, add a glow to it for instance and , while in your timeline cut or dissolve to that element from the non-effected element. The result is that section will appear to glow and highlight itself. Make each piece of the graphic with both a glow and without. By simply editing in the different pieces as your timeline progresses, you can “highlight” any section of it. Much quicker and simpler that the traveling matte route.
    Tom
  • Ramone Kalsaw
    July 22, 2008 at 2:14 am
    Seems pretty simple; I’ll try it. Thanks.
