Activity Forums Adobe After Effects Expressions Dynamically control x,y property of keyframe
  • Dynamically control x,y property of keyframe
    Posted by Matt Miller on March 17, 2021 at 4:41 pm
    I was hoping someone could help me create an expression to accomplish the following. I have a simple two keyframe animation and I would like to control the x,y values of the second keyframe by using values from a separate text layer. So basically I could input something like 0,20 in my source text layer and it would adjust the the position values of my second keyframe to match (0,20).
    Thanks in advance!
    Matt Miller replied 5 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 17, 2021 at 5:15 pm
    Maybe something like this, unless you need to preserve your easing, which is a whole different story:
    t1 = key(1).time;
    v1 = key(1).value;
    t2 = key(2).time;
    txt = thisComp.layer("text").text.sourceText.split(",");
    x = parseInt(txt[0],10);
    y = parseInt(txt[1],10);
    linear(time,t1,t2,v1,[x,y]);
  • Matt Miller
    March 17, 2021 at 6:23 pm
    This worked perfectly! As always, thank you so much for your help!
