Activity › Forums › Adobe Audition › Dynamic Processing Filter
Posted by Anthony Thomas on April 8, 2007 at 3:55 amDoes someone have some insight as to how this filter works? I have modified a filter preset called ‘Classical Knee’ and sometimes on crescendo passages, really loud sudden passages(quiet,bam,quiet), the notes drop out from the loud passages. Any ideas which parameters might control this.
Walid Jacob replied 16 years, 7 months ago 4 Members · 10 Replies -
Willie Toth
April 8, 2007 at 12:23 pmIt is a limiter try adjusting you settings … The other thing you may want to experiment with is the hard liming feature instead of the filter you are currently using ………. WILLIE
Anthony Thomas
April 10, 2007 at 1:52 amThe symptoms I describe, is it effected by adjusting the attack or release parameters. The dynamic processor has an attack and release for both the input as well as output levels. The preset, ‘Classical Knee’, has a lookahead time set to 3ms rather than 15ms which is the usual. Is 3 ms more in sync with classical?
I know, I will eventually get to the Hard Limit Processing, but humor me with this one just once.
Emmett Andrews
April 10, 2007 at 5:56 amThe preset name is “Classic Soft Knee” and has nothing to do with classical music. Generally, you wouldn’t want to compress classical music at all.
I think it’s important that you understand how dynamics processing works. The knee simply refers to the bend in the graphical plot. A “hard knee” would plot as two straight lines. A “soft knee” makes more of a curving shape.
Take the time to read the help file and some other material on compression. Understand attack, release, ratio and threshold and you’ll have a much better idea of how everything functions.
Emmett
Willie Toth
April 10, 2007 at 12:50 pmThere is no absolut right way to set attack and release … Attack and release controls operate together so to get the proper setting you need to experiment with the settings … The more sound you have the longer the look ahead time I like to use … I would use 12 to 15ms … Attack is how long it takes the compressor to start compressing … Release is when the compressor closes down … I hope this helps ….. WILLIE
Anthony Thomas
April 10, 2007 at 9:21 pmI am a hobbyist and I will look at the help files more closely. About compressing classical music – I have used audition to normalize (and this may not be compression as you speak of it) a lot of my classical music and I hear sounds that were not so obvious on my original cds. Of course I would never throw the originals away.
Willie Toth
April 11, 2007 at 1:02 amHere is a link for the DBX 266 page 7 has a couple of paragraphs that will help explain in more detail ……… WILLIE
Emmett Andrews
April 11, 2007 at 3:41 amNormalization doesn’t alter the dynamics…It simply amplifies the entire file equally. Normalizing to 0dB (100%) is similar to turning the volume of your stereo up as loud as it will go without distorting. Compression makes the file more even, as far as dynamics are concerned. Normalization doesn’t change the relative dynamics.
In addition to Willie’s recommendadtion, also read iZotope’s Ozone Mastering Guide: https://izotope.com/products/audio/ozone/OzoneMasteringGuide.PDF
While it’s designed for Ozone and mastering, it’s really good at explaining compression and limiting in terms that are easy to understand. If you’re having trouble grasping something you read, skip it…This guide will really help you, and it’s a good article for beginners and pros alike!
Emmett
Anthony Thomas
April 12, 2007 at 2:49 pmThanks to the both of you. My problem was in the attack parameter for the input file. It was too small. I will also put these documents you refered me to to good use.
Willie Toth
April 12, 2007 at 3:41 pmGlad we could be of service … Again I would suggest you play with the hard limit it will fatten things up a bunch ……….. WILLIE
Walid Jacob
January 29, 2010 at 2:25 pmneed help for dynamic proccesor filter in cool edit pro2
how to compress +10 db from 0db to -6db & expand +10 db from -7db to -16 db in the same time need a number for ‘input; output’ release; attake; ratio ; threshold’ thx you
