Activity › Forums › Adobe After Effects › Dynamic Linking from Premiere- single frame overlapping bug
  • Dynamic Linking from Premiere- single frame overlapping bug
    Posted by Jim Bachalo on October 20, 2013 at 9:02 pm
    There is an annoying bug with dynamic linking whereby instead of a clean cut between shots, you end up with a single frame that overlaps with a dissolve.
    The end result being a single frame that ends up darker in the final render.
    The only solution I’ve found is to manually option-shift click the ends of the shots on the layers to re align them.
    Does anyone know of a better solution?
    Local is the new global
    Todd Kopriva replied 12 years, 11 months ago 2 Members · 1 Reply
  • Todd Kopriva
    October 21, 2013 at 6:40 pm
    Please report bugs here:
    https://adobe.ly/ReportBug
    After Effects team blog
