Activity Forums Adobe Premiere Pro Dynamic link refresh?
  • Ramon Menting
    January 19, 2016 at 9:56 am
    A trick to ‘refresh’ those AE comps is to set the opacity to 99% in premiere. In that case premiere doesn’t use the older renderfiles anymore, so the changes appear. Found it faster working that way. It is a bit of a bug though.
  • Lindsay Penn
    March 31, 2016 at 10:56 pm
    I’m having this same problem and the opacity change isn’t working. The only thing that works is quitting Premiere and re-opening it, but doing that after every edit would drive me insane. Anyone have any more ideas?
  • Sam Katz
    April 26, 2016 at 9:33 pm
    For me, this issue only happens when I’ve already created an AE comp and I import it into Premiere. If that’s the case for you too, the workaround is to create a new AE comp from inside Premiere (File>Adobe Dynamic Link>New After Effects Composition). Then in AE, just plop your existing comp (now a precomp) into the comp you just created from Premiere. For some reason, Premiere maintains the Dynamic Link to this comp better, so when you make changes to your existing comp in AE, they update in Premiere as they should. Hope this helps!
  • Gracinieli Antunes
    December 12, 2016 at 5:07 pm
    This opacity trick works for me, Thank you! 😉
Page 2 of 2
