Activity › Forums › Adobe Premiere Pro › Dynamic link refresh?
Posted by George Loch on November 1, 2011 at 5:26 pmI have a Premiere Pro project where I am using a dynamic link to AE comps on the timeline. I assumed that when I made changes to the AE comp they would update in Premiere but, I can’t get it to reflect the changes. Is this a known issue?
-gl
twitter: @georgeloch
web: https://georgeloch.comGracinieli Antunes replied 9 years, 8 months ago 9 Members · 14 Replies -
Kevin Monahan
November 1, 2011 at 6:33 pmWorking fine for me. Do you have Production Premium or Master Collection installed? That’s the only way to get dynamic link between After Effects and Premiere Pro.
About dynamic link: https://help.adobe.com/en_US/premierepro/cs/using/WSbaf9cd7d26a2eabf53ab041041081290f-7fe8.html
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Tom Daigon
November 1, 2011 at 7:10 pmMake sure you SAVE in AE before toggling back to PrP. I have never bumped into this issue and I use DL a lot.
Tom Daigon
Avid DS / PrP / After Effects Editor
http://www.hdshotsandcuts.com
Mac Pro 3,1
8 core
10.6.8
Nvidia Quadro 4000
24 gigs ram
Maxx Digital / Areca 8tb. raid
Kona 3 -
George Loch
November 1, 2011 at 9:50 pmIt is production suite. I assume DL wouldn’t work at all without it correct?
-gl
web: https://georgeloch.com -
George Loch
November 1, 2011 at 9:52 pmHmmm. Well, I have saved both and closed both and brought them back up and they still don’t reflect the changes.
Strange stuff
-gl
Tom Daigon
November 1, 2011 at 9:56 pmThat is very strange stuff. Yes, if you just bought PrP and AE (not the suite) it is my understanding that they wouldn’t work.What are the versions of PrP and AE ?
Tom Daigon
Mac Pro 3,1
8 core
10.6.8
Nvidia Quadro 4000
24 gigs ram
Kona 3 -
George Loch
November 1, 2011 at 9:56 pmOk. I deleted the render files and re-rendered the entire sequence and the updates appeared. I should have tried that before asking.
-gl
Tom Daigon
November 1, 2011 at 9:57 pmNice. Good trouble shooting. I will have to remember this trick if I ever bump into this issue.
Tom Daigon
Mac Pro 3,1
8 core
10.6.8
Nvidia Quadro 4000
24 gigs ram
Kona 3 -
Jules Oille
August 12, 2012 at 3:22 amDynamic Links WAS updating right away but not any more!
To refresh my Premiere Dynamic Linking I have to exit Premiere then start the program again.
Ugh! Memories of Premiere CS4 are coming back.
I am Running The Master Suite (whatever that pack is) and a pretty loaded computer. This must be a software issue.
julesdesign
https://www.julesdesign.ca -
Tom Daigon
August 12, 2012 at 1:39 pmMust be something. 😀
Im running CS6 on a Mac and a PC with LOTS of DL use. I have not experienced the issue you mentioned.
Tom Daigon
https://www.youtube.com/watch?v=XRIg6h-LIm0
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
Samuel Brosset
June 3, 2015 at 10:44 amI confirm that this problem exist in CC between Premiere and AE. The only fix i found is to erase render…
